How fast????
Old Mar 20, 2009 | 04:58 PM
Blknight6989's Avatar
Default How fast????
OK so this summer I will have all the parts in my sig installed along with a cutout and a custom ground cam with spec's similar if not almost identical to the polluter. It will most likely be on a M/T drag radial. Question is simple what kind of times do you all think I will be around. My best right now with full exhaust on a nitto is 13 flat. Thanks for any responses, just want to get an idea of where I should be at.
Old Mar 20, 2009 | 05:05 PM
slowandrichws6's Avatar
probalbly high elevens if you hook but you could probly say bye to that 10 bolt
Old Mar 20, 2009 | 05:11 PM
exactly what im thinking! and its gonna be a grudge car most likely and see more street duty than track so im hoping for it to hold for the summer and throw in a S60 next winter...anyone else have a guess at times?
Old Mar 20, 2009 | 05:20 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The rearend might hold for a little while since your car is an A4. My old A4 Z28 was cutting 1.5xs on the stock 10 bolt
