Broken Valve Springs
Old Mar 22, 2009 | 02:14 PM
12secSS's Avatar
Default Broken Valve Springs
So I took apart the driver's side valve cover to inspect the FOD I had found on my oil drain plug magnet during my oil change. This is what caused it! Over 45,000 miles of abuse racing and WOT. I did however allow the engine to reach operating temps when I daily drove to work. The 1st picture is #5 intake spring and the other is the #7 intake spring (lower portion is collapsed). I just ordered new Patriot dual springs to replace these, they will be on the car by the weekend. Luckily it is only a 2 hour job.
Old Mar 22, 2009 | 02:19 PM
Nitroused383's Avatar
What valve springs are in there? Looks like you got lucky, good catch.
Old Mar 22, 2009 | 02:28 PM
12secSS's Avatar
Some old patriot duals I had laying around from a different build. I would say so, glad I didn't drop a valve.
Old Mar 22, 2009 | 07:31 PM
35th SS's Avatar
same thing happen on my m6 car.crane duals outer spring broke on #2 exh.vlv.now running prc duals 660 lift.
Old Mar 22, 2009 | 08:23 PM
SOMbitch's Avatar
I am going to try the PAC 1518 behives when my current duals go. Kinda pricey but I think worth it in the long haul..... I guarantee though the PACS will be on my next build...
Old Mar 22, 2009 | 08:29 PM
Soul TKR's Avatar
wow George good catch! YIKES!
Old Mar 25, 2009 | 10:07 PM
dudeman's Avatar
what valve seals were you using? which ones are you using now with the prc springs?
Old Mar 25, 2009 | 11:34 PM
RoDan's Avatar
That is why I am a fan of dual springs. You have sort of a safety net, if the outer breaks you wont drop a valve and vice versa for the inner. With a single... eh, hope and pray.
 Michael S. Palmer
Old Mar 26, 2009 | 08:37 AM
12secSS's Avatar
Currently, what ever is stock on the 317 heads. When I replace them, it will be what ever Patriot sends with their springs (Viton I believe).
Old Mar 26, 2009 | 08:45 AM
Eskimo's Avatar
But if you're running a quality single spring that's the proper spring for the application, you stand less chance of it breaking in the first place. AND, you get a lighter, more free-revving valvetrain.
Dual springs aren't there as a safety net - they're there when the engine build dictates it.
To me, replacing one set of patriot springs with another is just
Old Mar 26, 2009 | 10:11 AM
12secSS's Avatar
These springs actually have over 45,000 miles on my car (unlike I previously stated), previously used on a diffenret vehicle project of mine. They were not brand new when installed on this car, if that is what some of you are thinking, these were used springs! I am replacing them with new springs.
Old Mar 26, 2009 | 10:29 AM
SilverSS's Avatar
Did you notice a decrease in performance? If the outer spring broke, would you still be able to tell right away or not?
Old Mar 26, 2009 | 11:38 AM
12secSS's Avatar
My wife took it drag racing and ran a 7.71 @ 91, that weekend I changed the oil and noticed a piece of valve spring on the drain plug. I parked it until the next weekend to diagnose the valve spring, which are the pics you see above. No loss of performance was noted prior to the findings. This post was merely to inform people to check your springs once in a while.
Old Mar 26, 2009 | 01:09 PM
DGraboyes
Guest
Posts: n/a
how can you tell they went bad... im not exactly sure what im looking at in the picture...
my ls just started making a horrendous noise
http://www.youtube.com/watch?v=qFqrF7mMhh4
and i wanted it to be a valvetrain problem .. of course no one wants bottom end problems
what do you think/what should i look for
Old Mar 26, 2009 | 02:23 PM
silverLSWON's Avatar
i had springs break before, thank god for dual valve springs. i was driving down the highway normally and then my car started missing. when i checked over everything i found 1 broken valve spring. replaced them with all new patriot golds and has been fine ever since
Old Mar 26, 2009 | 02:53 PM
12secSS's Avatar
The top picture clearly shows a broken spring! Out of the five coils, four are still intact. Look at the second to bottom coil, it stops winding around the valve. That is a broken coil.
EDIT: Based on your video it is hard to tell, but it sounds like a rod knock or a broken intake valve spring. It could also be the intake rocker failed or fell off.
Old Mar 26, 2009 | 03:12 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
45K miles on those springs are pushing it to start! Even the beloved PAC's won't appreciate that abuse for 45K miles!
Glad you were saved
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
