Ring Gaps
but I happened to F* up 2 top compression rings by .001".
Bottom ones are really easy top however require a bit more grinding. Anywho...Anyone know if a vendor sells piston rings separate other than a whole set for a 99 ls1 standard bore 3.897+.005 1.5mm 1.5mm 3.0mm Thanks
