Polluter with rocker arms come in!
Old Mar 25, 2009 | 10:36 AM
95Lwind05's Avatar
Default Polluter with rocker arms come in!
Hey guys I have my Polluter cam installed. I was just wondering if anyone has ever used a larger rocker arm with it. I've got Comp Ultra Gold 1.72's, they wont be adding much lift but is it going to be putting it to close with PTV...Im very low on money and cant afford to take off the heads to check. I will if I have to but its going to delay everything another week or two. Any info would be appreciated!
Old Mar 25, 2009 | 11:40 AM
vettenuts's Avatar
Not sure what ratio those rockers come off the seat with. Stock comes off the seat at around 1.54, Crane comes off the seat at 1.79 so you can see that initial valve motion of the Crane will be more than the stock. The final ratio is irrelevant and the 1.72 is likely not achieved until midway through the rocker motion. You need to measure.
