New to lq motors help!!!
sorry i am new to these motors... the reason i want to do iron is cause i want to start out with some juice maybe a 125 shot and then in the future forge it for a turbo set up and new heads
Thanks
Thanks everyone
youll be fine with either, as an lq4 will save you a ton of cash most of the time.
OP-your heads will be fine on the bigger motor, just not optimal.
with the torquer cam, you should be ok if the heads have not been milled, but its always good to check ptv clearance.
I know that the lq4 has less compression than the lq9 but if i do decide to use either of these motors with the heads and cam from my ls1, will i still see a boost in power since these motors are bigger than my ls1? for now i am just looking at a low mile short block and keep the stock internals until i have enough money to do forged... about how big of a shot of nitrous can i run through a stock bottom end in these motors?
And has anyone use a ls2 timing chain or a ported ls6 oil pump in these motors?
Again sorry if i am ask stupid or dumb questions i am just new to all this
youll get a nice boost in power from the 6.0, regardless of the commpression.
ptv clearance checking is a procedure that needs to be done to make sure you have correct clearance.
just turning the motor over by hand wont cut it.
metal expands at different temperatures/forces and its possbile to make contact while running when it didnt turning it over by hand.
And do you guys think the stock bottom end of a lq4 or lq9 will handle a 100-150 dry shot of nitrous and still be reliable? it will only be use on the weekends at the track
And with my setup which of these short blocks would you use the lq4 or the lq9?
Thanks again for all the info!!!
LQ4 is your motor for boost
or nitrous..
05+ lq4 has the good rods. Best bang for the buck motor. 06 has heavier ls2 timing chain i believe also. If not present this is a good part when throwing in a cam, but not necessary if the engine is pretty low mile.. used LQ4's are very common and cheaper than the LQ9 with the slightly higher comp. You can shave the heads for an increased comp ratio as well for another option.
You should have no problem with stock bottom end making 650+ hp so that little shot of nitrous shouldn't make it bat an eyelash.. These engines have been pushed to more than 7-800 with as little as arp rod bolts. make sure you follow up with a tune so you don't burn up a piston tho.
Is there anything else i should know about doing this kind of swap? since i am new to this any little tricks and tips will help... like what head gaskets to use since i am using my ls1 heads? or anything else along those lines
Thanks to everyone who chimed in and helped answer my questions!!!
to make them live at that power level requires flawless tuning and a perfect fuel setup. not to mention having a plug that wont melt a hole in a stock piston.
On the nitrous part... if anything the 04-up LQ4/9 would hold up to nitrous better than the LS1's just for the simple fact they have better rods and they are iron block with better head gaskets. I'm getting ready to install a NX shark nozzle kit on the t/a and spray a small 100 shot on it. I have not doubt in my mind that it could hold a 200 hit if I had the fuel system to back it up.
A little advice if your working with an F-body... All my stock fuel pumps have crapped out around the 430-440 rwhp range which is good for about a 100 shot on a stock longblock LS1 with full bolt-on's. I have upgraded to a single Walbro 255 in-tank and I have made 496rwhp on a stock longblock LS1 on a 150 shot without any fuel pressure issues. The Walbro is a must if you spray a wet shot!!!
