What head Gaskets to use
Im getting ready to install my newly CNC'd 243 Heads, what gaskets do i need to use? the 98 graphite style or the new ls6 ones??
thx
http://www.sdparts.com/product/12498...2002andUp.aspx
this pn here for 97-01
http://www.sdparts.com/product/12498...GasketKit.aspx
your 243s should be the newer gasket style...the 12498544
that is for a complete set of head gaskets. then of course you will need the hea bolts, valve cover gaskets and any necessary intake/air/egr gaskets.
we have those in kits as well, just let me know what you need and ill get you set up.
So....with the 98 style ls1 block what gasket should i use with the 243 head?
If the difference between the PN you listed for graphite and non and thickness?
We are measuring them right now to see if GM has changed the design to publish a .051/.053 for all of them.
Ill let you know in a little bit.
But I can use either gasket and be fine...correct
What gastket is better suted for abuse?
I also saw that thinkness difference also.
8543 graphite will be .051 when compressed
BUT
8544 looks more like .057 to .059 when compressed.
These are brand new gasket kits, they just came in the other day.
Ill change the specs on the site.
the 241s should not have the notch. They are on the outside edge between the bolt holes on the outside right at the corner of where the deck surface comes up to teh exhuast manifold port side. the graphite gaskets are designed with a silicon printoseal to keep from leaking. The other gaskets are not and will leak.
