853 Heads
Old Mar 26, 2009 | 09:21 PM
wakesk8te's Avatar
Default 853 Heads
Just was wondering.. I picked up a set of 853 (I believe that's the casting) from a friend.. Will I be able to bolt these straight on to my 01 LS1.. I know some valve covers dont match up..
And can anybody give me the best approach to make these heads flow the best..??? (valve sizes, port pics, etc.)
Old Mar 26, 2009 | 11:55 PM
Damian's Avatar
LSX Mechanic
EDIT- Didn't read the post correctly.
Old Mar 27, 2009 | 12:27 AM
thebulgd's Avatar
I'm running 853s and they are center bolt, four bolts down the center of the head for the valve cover. Dunno if there are 853s that are perimeter bolt, but I do know both sets of 853s I have are center bolt. Port the **** out of them ******* and bolt em one.
BTW, my 853s have coil brackets, not individual coil mounts.
Old Mar 27, 2009 | 12:37 AM
Damian's Avatar
LSX Mechanic
Never mind, I didn't read the post correctly. I was thinking 806's/1998 heads. Excuse my lack of reading
Old Mar 27, 2009 | 12:41 AM
02 BLK WS6's Avatar
If you have an '01, then you have 241 casting heads. 241 heads flow better and the casting were marginally better than 853. Porting each levels the playing field, but I have heard of slight shifting in the 853 castings that will affect them even in ported form.
Old Mar 27, 2009 | 08:53 AM
EVIL z28's Avatar
The 853's also require the graphite gaskets instead of the MLS due the the notch cut in the deck. I would keep the 241's.
Old Mar 27, 2009 | 12:40 PM
02 BLK WS6's Avatar
Not all 853 heads require the graphite gasket. I burned a valve last season, so I had to pull a head. There was no notch, so it went back together with a new MLS gasket with 3 coats of copper spray. The other side still has a graphite gasket. I have not had any issues with pushing water on a 200+ shot.
