what else would i need
Old Mar 27, 2009 | 05:54 PM
emolineaux's Avatar
Default what else would i need
ok could i use stock pushrods rockers and what not on this setup or would i need new stuff. if so let me know what i need.
im going to be running a set of 243s on my 98 z28 and im looking at getting this cam
GM ASA Cam 226/236 .525"/.525" 110 LSA
i dont know if i can use the stock rockers and pushrods but all info would be greatly appreciated.
thanks for your help.
by the way i will be using a stock thickness head gasket
Old Mar 27, 2009 | 06:29 PM
DaveX's Avatar
Stock rockers are fine. Most likely you will need longer pushrods, and you should upgrade to hardened pushrods anyway. And you will need springs to match your cam, and TI retainers are a good idea but not required.
Old Mar 27, 2009 | 06:33 PM
4.6what's Avatar
+1 on the hardened pushrods!!
