Heads for my setup questions
Old Mar 29, 2009 | 11:06 AM
djfury05's Avatar
Default Heads for my setup questions
Current setup ( Not Installed )
-TR 230/236 .591/.601 112 + 4 lsa
-Patriot Dual gold extreme valvespring kit .660 capable
-Comp Cams Hi-Tech Pushrods 7.400
-Manley Double roller timing chain set
-Melling high volume oil pump (10296)
-Racetronix Fuel System Kit
-ASP 25% underdrive pulley
Was thinking about getting 243 heads with the sodium valves if I can find them and had some questions about them. I've searched and searched and there has been no concrete answer.
Here's my questions
When I do get the heads should I get them ported? If so to what extent? Should I get them milled? I really have no idea about any of this kind of stuff so any input would help greatly. And for what it's worth, I plan to get a Fast 90/90 or 92/92 ported setup after I get all this stuff. Just give me some suggestions on what to do please! Or even suggest different heads that aren't $24,000 per pair lol. Thanks!
Old Mar 29, 2009 | 11:38 AM
Unertl42's Avatar
If you haven't bought the heads, check out patriot. Their heads are great and and the prices are good. You could get an assembled set, and sell you dual golds on the for sale section
Old Mar 29, 2009 | 11:41 AM
conan's Avatar
Texas speeds PRC heads are another great head that wont brake the bank.
Old Mar 29, 2009 | 11:47 AM
1bdtrk's Avatar
From: Currently, Zormat, Afghanistan....Home staion, FT. Richardson, Alaska
Get ahold of bret bauer, worth the money and youll be straight. How many cubes for your setup?
Old Mar 29, 2009 | 11:58 AM
djfury05's Avatar
346na
Old Mar 29, 2009 | 02:14 PM
1bdtrk's Avatar
ya, get bret to set you up with a set of ls6 heads and port a fast intake/tb while hes at it. maybe even have him spec a cam for you. youll be straight then.
