What affect does advance ground into a cam have?
Thanks, Shawn
Advancing the Cam will....
1) Lower the RPM where motor makes peak HP
2) Increase cylinder pressure by changing the intake valve's closing point.
-Geoff
im a little lost too. and gonna be really pissed if the cam i ordered 230/230/114 +3 idles like a 110lsa cause its going in my a4 car and i wanted a decent idle with a lower powerband. please tell me that this cam is not going to be comparable to a 110lsa....
JR
Adding advance lowers the peak and gives you more low end or off the line torque but sacrifices top end power as the peak will roll off sooner. It's not this simple but when you consider intake manifold, exhaust, gearing and stall you can determine where a cam ICL should be set. Most times, it's just trial and error and / or experience that determines the ICL.
