Lifter Question
Old Mar 30, 2009 | 01:12 AM
NBM-LS1's Avatar
Default Lifter Question
I wasn't paying attention when I took the stock lifters out. Does it matter what way the hole for the oil in the lifter is facing? I faced all the holes towards the front. Is that ok?
Old Mar 30, 2009 | 04:49 AM
vettenuts's Avatar
Yes, that is fine. Did you keep them in the correct position?
Old Mar 30, 2009 | 08:20 AM
NBM-LS1's Avatar
As in correct position for each cylinder? No. I was putting in new ones so I just pulled the stock ones out but was not paying attention the where they were.
Old Mar 30, 2009 | 08:35 PM
Geezel's Avatar
When I pulled my factory installed lifters the other day, there was no pattern as to which direction the holes were facing. The installation procedure in my FSM doesn't address hole direction either. I guess it doesn't matter.
Old Mar 30, 2009 | 08:55 PM
NBM-LS1's Avatar
Thanks my good sir.
