will this cam work with stock injectors
Doing a h/c swap and have been told stock injectors would world work by some and that it would not by others
any help would be great
cam specs are 236/242 615/612 111+2
Thanks Derek
Thanks Derek
Seeing that you have 2000 means you have 26lbers stock. They will not work with a H/C combo. Will it run with them, yes, but as soon as you WOT you will run lean and risk hurting the motor. I have 28lbers on mine they are at like 92% duty cycle which is still to high and I'm cam only. I think the rule of thumb is being at 80% duty cycle on your injectors with whatever combo you run to be safe. Your gonna need at the very least some 36lbers or bump up to some 42lbers.
Im running a simular cam from TR its the Raptor cam and its 236/242 617/613 on a 111+2 im running the stock injectors and my car runs great with injectors at 85% I need to move up to 36 lb hr from what shane said at TR give them a call and they can set you up.
You really only need some SVO 30# injectors. Cam only you should even be ok with the stockers. Add heads, you will need injectors. You really do not need 42#'s untill you go bigger cubes or FI.
