Front Drive Distributor on an Ls1
Old Apr 4, 2009 | 09:50 PM
Macrapper1's Avatar
Default Front Drive Distributor on an Ls1
IS this set up worth it..... do you guys have pics of it....... Do you install it the same as a rear distributor or is it different, how does it work
Old Apr 4, 2009 | 11:38 PM
5.3LJimmy's Avatar
I don't think it can be used with the stock PCM, and it will not add horsepower. I've only seen it used on high horsepower/high RPM setups with aftermarket engine management.
Old Apr 5, 2009 | 01:32 AM
fast01's Avatar
I may be wrong, but I believe it uses a small block Ford type set up.
