Change Reluctor Wheel Help
Old Apr 7, 2009 | 07:23 PM
solsticels2's Avatar
Default Change Reluctor Wheel Help
I have to change my reluctor wheel on my 06 Trail Blazer SS motor from the 24 tooth to the 58 tooth..... Can this be done??? and who can supply the 58 tooth and or possibly install it for me?
Old Apr 8, 2009 | 03:21 AM
1FastBrick's Avatar
Yes can be done, but you need the tool from goodson. Any Machine shope might be able to do it but the tool indexs it properly.
SDPC should have the wheels and I think Lingenfelter also has the wheels.
Other sponsers may have them but I am not sure wich sponsers.
Old Apr 8, 2009 | 06:28 PM
Thumbs up Thanks
Thank-you Brick thats good news for my conversion project.
Old Apr 8, 2009 | 08:42 PM
1FastBrick's Avatar
The reluctor wheels are the cheap part... The Special Tool is the killer. Of course you can usually sell it and get most of your money back. With out knowing were your located It hard to say a shop that could do it for you. There may be some one in you area that has the tool That could do it for a reasonable price... basically the wheel gets heated to like 400 degrees or so and it it slips right over the rear up. You let it cool and it shrinks just enough to keep a tight fit. Once it cools you need to check it for run out and adjust it accordingly.
There is also a conversion Box that Lingenfelter sells to convert the signal so you dont have to mess with taking any thing apart.... Might be a better route to go...
Lingenfelter TRG-001 58x To 24x Crank Sensor Trigger or Reluctor Wheel Conversion Module
Part Number: L460065397
Price: $254.95
http://www.lingenfelter.com/
Old Apr 8, 2009 | 09:46 PM
socal's Avatar
just get the lingifelter convertor box. heres alinks to show you what im talking about
https://ls1tech.com/forums/new-produ...er-module.html
Old Apr 8, 2009 | 09:49 PM
Hey Brick you ain't gonna believe this ...... I'm trying to get from 24X to 58X and they are doing it 58X to 24X ..... Just my luck ! I live in Canada and still hope to find a shop with the tool nearby.
