cam to big, recommend a smaller one
Old Apr 10, 2009 | 06:33 PM
99tankta's Avatar
Default cam to big, recommend a smaller one
Patriot stg 2 6.0L with 2.055 - 1.57 ferrera valves, stock 346...well i purchased a cam from futural f14, went to put the cam on and with these heads the cam will hit the bigger valves (2.055). So i need your advice Cam gurus on what cam i would be able to use prefer a choppy cam 112lsa....
thanks for any help guys and gals..
and the f14 cam will be on the forsale thread...
Old Apr 11, 2009 | 04:04 AM
corvet786c's Avatar
These guys make great streetable cams Look at the 049 cam, Would build great power on a 112 LSA. JMO
http://www.vincihiperformance.com/CA...%20LS1%202.htm
Old Apr 11, 2009 | 05:12 AM
PREDATOR-Z's Avatar
228/228 .588/.588 112+2 LSA
AKA 228R from TSP >>>sponsor
Old Apr 11, 2009 | 08:23 AM
99tankta's Avatar
thanks
Old Apr 11, 2009 | 08:49 AM
02SOMWS6's Avatar
224/228 581/588 110 lsa
with that little cam and worked over factory 242 heads and a 12 bolt rear with 4.33 gears and a steel drive shaft I put down 452 rwhp and 401 rwhp before I went with a bigger cam. You could always flycut your pistons instead
Old Apr 11, 2009 | 09:07 AM
99tankta's Avatar
im trying to keep from flycutting, but if i have to i will
