LQ4 question
Old Apr 11, 2009 | 12:54 PM
transammiller's Avatar
Restricted User
Default LQ4 question
what all is required to install an LQ4 into a 1998 Trans Am? i have a set of 243 heads, FAST 92/95, and 1 7/8 LTs. will my accessories and oil pan all bolt up? as well as motor mounts? anything i should know?
Old Apr 11, 2009 | 01:35 PM
smask04C5's Avatar
Yes, it will interchange
Old Apr 11, 2009 | 02:03 PM
NemeSS's Avatar
also need to install oil psi sensor off your 98. not the same connector. everything else bolts on, plugs up
Old Apr 11, 2009 | 04:16 PM
PREDATOR-Z's Avatar
You will need center bolt valve covers, coil mounting kit.
You'll have to swap crank pulley and drill/tap a third alternator bolt hole (LQ4 just has 2).
All else pretty much just bolts on.
Old Apr 11, 2009 | 09:49 PM
sroach20's Avatar
the ground wire that comes off the battery and goes to the block is also in a different spot.
Old Apr 11, 2009 | 10:21 PM
Restricted User
it seems the guy made a mistake. it's an LQ9. i am bolting 243 heads to it. the grounding strap should still be in the same place on thoise. will the oil pressure sender still need to be swapped? also will an LS6 oil pump work with it as well?
Old Apr 11, 2009 | 10:23 PM
sroach20's Avatar
lq4 and lq9 are the exact same blocks. the ground cable coming from the battery is mounted to the block a little closer to the front.
