What do you think about this cam?
Old Feb 15, 2003 | 02:49 PM
MHop3190's Avatar
Default What do you think about this cam?
I was originally considering going with the MTI B1 cam, but I realized that emissions really isn't an issue for me and I wanted a little "more" cam since I was going to get dyno tuning as well. Originally I'm going to keep the cam with stock heads but will probably do stage 2 heads in a year or so. The cam I'm now considering is the C1 cam from MTI. The specs are as follows:
222/222 Duration .566/.566 Lift 112 LSA
Do you think I'll be happy with this cam? The idle quality should still be pretty good and I'd like the idle to be a little more "rougher." I am going to have the car dyno tuned after instalation so they can mess with the idle and the rev limiter.
Old Feb 15, 2003 | 03:07 PM
Cal's Avatar
Cal
Default Re: What do you think about this cam?
Good question, Mhop! I was about to post the same thing, but then I saw your's! I would like to add to this, Does the Hammer cam (C1) make your LS1 sound like a sewing machine, as do some other cams?
