smogable h/c setup - please advise
to be on the safe side should I go with AFR heads then since its got that CARB stamp? Idkkkk...... which heads to go with
You don't have to worry about heads not passing smog(sniffer), as long as they look stock. I have the Patriot stage II's,custom 224 cam on a 114 lsa, high flow cats, and I've passed twice..both times with max values for ppm.
