Swapping motors and ran into problem with timing chain
Old Apr 14, 2009 | 12:26 PM
slowrollin93's Avatar
Default Swapping motors and ran into problem with timing chain
So I swapping my 5.3 out for a ls1 in my truck, i was in the process of switching everything over and I saw that the timing chain sprocket on the ls1 is alot different than the one on my 5.3. I think its part of an aftermarket chain set. What should i do now?? Do i have to take both motors to a shop and have the sprockets pulled off and have the stock on pressed back on or what, could i just buy the rest of the timing chain set for the one thats on the motor now? If so how would the oil pump even go on it??
Old Apr 14, 2009 | 12:44 PM
H8TO WRK's Avatar
Just buy a puller to pull that off.
Old Apr 14, 2009 | 12:59 PM
what kind of puller would i need? I have a couple 3 jaw pullers
Old Apr 14, 2009 | 02:21 PM
vsocks1's Avatar
3 jaw should work if you can get it setup correctly. GM has a special tool which is basically a half plate with half circle cutout that slips behind it and has 2 bolts to pull it off.
Old Apr 14, 2009 | 02:28 PM
Randy WS6's Avatar
The sleeve is to drive the oil pump, It pretty easy to get off. I use a sharp screwdriver and drive it between the cam sprocket and the oil pump drive sleeve,and it pops right off.But you can use a puller and pull the sprocket and sleeve at the same time if you need both
Old Apr 14, 2009 | 10:14 PM
3 jaw with some grider modifications to it got it right off.
Old Apr 15, 2009 | 08:03 PM
01ssreda4's Avatar
i had better success with a 3 jar puller converted over to 2 jaw. some pullers can be either or. it was like the 4 inch size.
