iron block ls1 with milled 5.3 heads?
Old Apr 14, 2009 | 02:15 PM
erollinc's Avatar
Default iron block ls1 with milled 5.3 heads?
just a thought.... on a really stiff budget
get an lm7 for next to nothing
get used ls1 pistons for next to nothing
punch it out to a 5.7
mill the 5.3 heads to get 11.5 compression
get ls6 intake
put a 230/232 cam with a 112 lsa in there
do headers and intake ... basic bolt ons and such
will she make 400 whp on a six speed? i may have to hand port / polish the heads since they need it... are the valves just too small to make it? i figure they cant be much worse than stock ls1 heads and the added bump in compression should help.
i know ive seen ls1s with stock heads and 10:1 compression make 400 wheel....this should do it right?
Old Apr 14, 2009 | 02:39 PM
erollinc's Avatar
oh and for all you guys who are going to say screw an lm7 just get a lq4, ive seen complete engines with everything go for 2-400 dollars vs the cheapest i see 6.0s go for being 850-1100 ... thats alot of savings.
will i need the ls1 rods too?
Old Apr 15, 2009 | 09:27 PM
MasterMindMotorsport's Avatar
I had the same idea. I wanna know if its bore or stroke that makes it a 5.7
Old Apr 15, 2009 | 10:32 PM
JDishong's Avatar
stroke is all the same, just bore difference.
