View Poll Results: What cam is best for my goals?
TSP 228R
19
39.58%
VengR VRX4
5
10.42%
Something from futral
13
27.08%
OTHER (Please Specify in thread)
11
22.92%
Voters: 48. You may not vote on this poll
Decide between 3 cams.
Old Jun 3, 2009 | 06:19 PM
  #41
PREDATOR-Z's Avatar
Originally Posted by WSsick
wow Pred. that curve is immaculate.
to the OP, i do nto see why you wouldnt hesistate to get that cam Pred speced out. thats pretty much all you are asking for. and predator z is one of the most respected cam gurus here.
as for getting the cam ground, not every shop just grinds cams. most (since Crane went out probably ALL) com out from CMP CAMS, so call them to get it with those specs or any sponsor and they will get it from COMP CAMS, either way, same place/grinder.
Thanks, here is the same car (as above graph) with Cartek 4x 243s and unported 90/90 (400lbs at 3500, yes it is a 346 )
BTW Lunati and Cammotion (Futral) are some other companies as well.
