Rod/Piston combo!
Old Apr 16, 2009 | 08:11 PM
BlackTA96's Avatar
Default Rod/Piston combo!
Well i'm looking for some new internals.
Wanna go forged of coarse. I plan on spray a big shot(250).
I was looking at eagle h-beams and some diamond piston. Not sure on what rings to go with yet.
What do you guys think about the combo?
Im definetly doing this on a budget. It's gonna take me a couple months to save up for them.
Old Apr 16, 2009 | 08:14 PM
Randy WS6's Avatar
I run Eagle rods & crank and Ross pistons with a 350 shot, and not had any problems at all, I use HellFire rings.
Old Apr 16, 2009 | 08:17 PM
BlackTA96's Avatar
Are you running a prgressive controller or is all that coming on at once?
You guys think the stock crank will take a 250 shot on a progressive? I definetly don't have the funds for a forged crank, and i've heard the stock 6.0 cranks were pretty tough.
Old Apr 16, 2009 | 11:21 PM
MelScrilla's Avatar
damn randy i've heard people say that eagle pieces don't hold up under big shots like that.
Old Apr 17, 2009 | 03:05 AM
ONEBAD383STROKER's Avatar
Eagle H beams with L19 bolts. Dont be scared.
Old Apr 17, 2009 | 08:17 AM
BlackTA96's Avatar
Yea, Yea....
I'll probably end up getting um.
I just need to figure out what pistons I want.
Old Apr 17, 2009 | 10:53 AM
99Ls1fever's Avatar
I run Compstar rods and diamond forged pistons with a 200 shot. Pistons and Rods costed me 1000 dollars. With the ARP Bolts torqued to 75lbs. She could hold a 300 Shot
Old Apr 17, 2009 | 10:57 AM
PREDATOR-Z's Avatar
Wiseco
Callies rods
Hellfire rings
Old Apr 17, 2009 | 11:03 AM
BlackTA96's Avatar
damn. Where'd you buy the rods and pistons from?
Old Apr 17, 2009 | 11:11 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm guessing you are using the 6L block in you sig?
Wiseco Pistons
Hellfire Rings
Any forged H beam rod with ARP2000 rod bolts
Old Apr 17, 2009 | 11:12 AM
99Ls1fever's Avatar
Altitude Intense Racing
www.ai-racing.com
303-587-4625
Ask for Clint and Trent (owners) good guys
Old Apr 17, 2009 | 11:17 AM
BlackTA96's Avatar
Looking into the Wiseco's.
They're pretty reasonable on the price. TSP has them for 581.99
Might end up getting Their -3.2cc piston
Old Apr 17, 2009 | 11:18 AM
Randy WS6's Avatar
I dont run a progessive controller, I spray a 100 shot dry off the line, the i bring in the 250 fogger in 2nd gear, I just got a N.O.S. controller and going to install it soon, And i run L19 rod bolts with my Eagle rods and high load rod and main bearing.
Old Apr 17, 2009 | 11:25 AM
99Ls1fever's Avatar
Question-
Does the Edge programmer have a proggresive control on spray? Cause I like the way your system goes from a off the line shot to a second gear throw down!
Old Apr 17, 2009 | 02:43 PM
www.ai-racing.com
303-587-4625
That web site is bad a$$.
Old Apr 17, 2009 | 02:45 PM
BlackTA96's Avatar
LOL. 10-4 on that one!
99Ls1fever's Avatar
Yeah I agree it need some work! I didnt know if they had finished it yet or not...
It is just a Local shop out here in Colorado that buys direct and gets the parts a lot cheaper!!!
Old Apr 17, 2009 | 02:50 PM
98TA6.0's Avatar
my bud's budget nitrous motor uses an LQ4 rotating assembly. he just tore it down and replaced the rings with a Total Seal steel top/napier 2nd ring set and Clevit bearings. he got the rods shotpeened and magnafluxed. he also has studded mains/heads as well as ARP Pro Series rod bolts. he makes 740+ hp with a heavily milled set of 317s with larger valves and a huge cam. if you still have your piston/rod combo then just save teh money and get the stock long block overhauled. I have a set of pistons and rods in good condition if you're interested?
Old Apr 17, 2009 | 02:53 PM
98TA6.0's Avatar
i have that exact same piston set and i paid $810 with a set of GFX piston rings (steel top/napier 2nd)
Old Apr 20, 2009 | 10:02 AM
BlackTA96's Avatar
I would use my stock rods and pistons...but the engine needs to be bored.
A few of the cylinder walls are in rough shape.
