Can ls1 head bolts be reused?
Old Oct 27, 2003 | 09:37 PM
lilxtra's Avatar
Default Can ls1 head bolts be reused?
I know they are torque to yield bolts but most of those I have dealt w/h on other cars are safely used up to 3 times but I'm not sure about the ls1's although I see no difference between them & any other head bolt.Thanks in advance for any info! Scott
Old Oct 27, 2003 | 09:40 PM
Country Boy's Avatar
Senior Member
NO! Throw them away!
Old Oct 27, 2003 | 09:49 PM
LS1x2's Avatar
Formerly 4mulaJoe
You aren't really suppose to. You will might get away with doing it or you might only get away with doing it for a little while before you get some leakage.
Old Oct 27, 2003 | 10:04 PM
Aidan's Avatar
Yes they can be reused...after the first use they are stretched and you can use more of a TQ setting than a angle torque setup.
But they are so cheap, why not replace them?
