the mysterious ticking sound
Old Apr 18, 2009 | 09:26 PM
evilz's Avatar
Default the mysterious ticking sound
well today i got around to swaping my heads and cam. i already had a custom ground comp cam, comp lifters, comp 7.400 pr and comp 918 springs and retainers. but once i got the heads off and started pulling lifters one didnt want to come out. so after having to use pliers to get out a lifter i originally planned on reusing i could see some damage to the cam. after getting the came out i noticed at least five bad lobes. 3 with like a round dipped shape and others had gashes. the one that didnt want to come out looked as if it was at an angle. i only had around 3-5k on this setup and it always made the ticking sound that everybody seems to have. one thing when i pulled the lifter trays out the lifters didnt come with the trays they just kind stayed where they were. hence my first question. is that normal? would pr legnth have someting to do with this? or is it the trays?
Old Apr 19, 2009 | 11:18 AM
evilz's Avatar
damn dont everybody jump on at once
Old Apr 19, 2009 | 11:20 AM
01FbTaWs6's Avatar
its normal for the lifters to stay in the block. If you didnt use a PR length checker then there is a good chance your ticking could have came from incorrect preload.
Old Apr 19, 2009 | 12:04 PM
evilz's Avatar
well im wondering how my cam got trashed i dont want this to happen to the new cam i have. i plan on checking pr length but wanted to know if the trays would cause this or if its a combination of the trays and pr.
Old Apr 19, 2009 | 07:26 PM
evilz's Avatar
anybody else
Old Apr 19, 2009 | 07:42 PM
First Collision's Avatar
I can't see the lifter trays causing damage to the cam, unless the lifters were installed incorrectly somehow.
Old Apr 19, 2009 | 07:44 PM
vsocks1's Avatar
When you replace the cam use new lifters & lifter trays. Check for pushrod length and set the right preload. That should get you started in the right direction.
Old Apr 19, 2009 | 07:47 PM
evilz's Avatar
ok wasnt sure about the lifter trays but i have a pr length checker. is their a how to on how to use this danm thing though
Old Apr 19, 2009 | 09:19 PM
SOMbitch's Avatar
IIRC Vettenuts has posted some good info on this.
