what heads came on a 2002 z28
Old Apr 19, 2009 | 07:40 PM
benji's_z28's Avatar
Default what heads came on a 2002 z28
just like the title says, what are the stock heads on a 2002 Z28? ive heard either the 241's or the 243's. so which one is it or am i not even close.
ive also heard that the 2002 f-bodys came with pretty much the ls6 engine except the cam. is this true??
help me out thanks
Old Apr 19, 2009 | 08:37 PM
Zach79Z's Avatar
a 2002 shoulda came with 241's i beleive and some came with ls6 BLOCK
Old Apr 19, 2009 | 09:01 PM
Red99TA's Avatar
help me out thanks
The only similarity to an LS6 motor that the '02 LS1 has is the intake manifold and some had the LS6 block as well. The true LS6 has a more aggresive cam and the 243 heads which outflow the 241's. Also the LS6's have slightly larger injectors (28.8#).
Old Apr 19, 2009 | 09:26 PM
ok thanks guys.
so on a similar topic....
i am looking for a pretty mild cam and doing a set of rr's.
i want something around 380 rwhp. would the ls6 cam do that for me or what would you guys recommend for me?
the reason i only want around that power is so i dont have to worry about me 10 bolt breaking.
Old Apr 19, 2009 | 10:30 PM
24/48's Avatar
Alot of guys break their 10 bolts at stock power level.
Old Apr 19, 2009 | 10:34 PM
EndlessSummer85's Avatar
TR or TSP 224 would be best on a 112lsa nice choppy idle and good dd cam that makes great power
Old Apr 20, 2009 | 11:29 AM
Zach79Z's Avatar
Id run the VRx3 from vengeance and you can make that easy. And im guessing by rr your meanin roller rockers and if your guna go with a 224 0r 228 cam id spend the money on a ported throttle body or somthing else
Old Apr 20, 2009 | 12:21 PM
i already have a ported throttle body. with doing the 224 or 228 cam would i have to do different pushrods or springs or can i just swap the cams??
Old Apr 20, 2009 | 01:15 PM
subhumanzz's Avatar
yes hardened pushrods and new springs are both needed.
Old Apr 20, 2009 | 04:49 PM
Zach79Z's Avatar
You could run comp 918s with that cam and prolly be safe with 7.45 length pushrods
