Would this make a nice DD
I have a fully bolted on Formula and I am looking to throw in a new cam. I'm looking at the Texas Speed 233/239 camshaft. What do I need to replace when I swap in this cam, anyone have a clue what type of hp i could lay down. Will the car still be a decent daily driver?
i heard alot of good things about the 228R, i believe you can keep the stock length rods because is the same profile, i believe if your only looking to change the minimum valve springs cause stock i think is .500 and that cam i believe is .588, go dual valve springs if you can afford good investment.
