Hot cam vs.. Tr 220 ????
6. Was this his first trip to the track with his combo? (I doubt it. Gimme some time to dial it in why don'tcha?)
It was the first time at the track w/ that combo. . .still untuned, but all of your other points are valid.
When all is said and done, I believe if I had a 3100lb raceweight, a custom wideband tune, and 15" bogarts all around, and of course a 12 bolt rear, I'd be in the running for the quickest cam only M6 car.
Very impressive shakedown to say the least.
Mike, any plans to experiment with different cams later on? If so, what? You sound like you have a pretty well dialed in car.
Actually PSJ was at the track last year when she did it. Yes that is a NA time for those who would question it.The Best V8 Stories One Small Block at Time
No plans to swap cams. . .I need to find a job first!
avezz28 asked the question of what was the highest trap speed of the 2 cams. He didn't ask about transmissions or weights. We never said that a TR220 will run that in any car you put it in but the fact remains that Angie turned almost 124 with a 220 cam in an A4.
If all you are concerned about when shopping for a cam is price and a rough idle then by all means get a hotcam. If you want a cam that will have better power throughout the entire powerband and have a smoother idle and better drivability then the TR220 or the TR224 is a better choice. Also as far as the TR220 being harder on springs, that may be true to some degree but it's not a huge issue. Angie still has the same Comp 941 springs that went on the car almost 3 years ago.
I think some people have the idea that you have to change springs every 6 months to a year with an aggressive lobe cam.
Seems to be that way. Everyone complained about the 941 springs breaking but we still have the same set on Angie's car. Granted the car doesn't have a ton of miles on them but they see severe duty 100% of the time.
Paul
