CAM / SETUP for AFR heads???
Old Apr 22, 2009 | 11:17 PM
rcjoe's Avatar
Default CAM / SETUP for AFR heads???
I recently bought this set-up from a fellow member on ls1tech, i was wondering if anyone can help me choose a cam, the car is a wknd driver, with an occasional trip to the strip. I'm planning on using a yank 3600 unless recommended otherwise. This will be going into a 00 formula ws6 a4, with most bolt-ons, such as exhaust, ARH headers, UD pulley, ls6 intake, etc. I will also get the racetronix fuel pump/upgrades. and injectors if needed
AFR 205's Milled .020
*New 650 lift Patriot Springs
*Valve Job and Inspected by G-Force
Texas Speed Hardened 7.4 Pushrods
Comp Lifters
ARP Head Bolts
Crowler Adjustable Dbl Timing Chain
now i have searched and searched.. i know most people are running 224 size cams.. i was just looking for any other suggestions, i have also been thinking about sticking in the afr cam. any HELP will be greatly appreciated thanks
Old Apr 22, 2009 | 11:40 PM
Detoxx03's Avatar
A Futral Motorsports cam
Old Apr 23, 2009 | 04:11 PM
rcjoe's Avatar
anyone out there.. tony mamo .. predator z
Old Apr 23, 2009 | 06:44 PM
corvet786c's Avatar
Comp Lifters
ARP Head Bolts
Get a streetable cam 222/228/115 Vincihiperformance. Has alot of torque and go well with those heads.
http://www.vincihiperformance.com/CA...%20LS1%202.htm
