Introducing The All New PRC Spring Kit
Old Apr 24, 2009 | 03:00 PM
Johny GTO's Avatar
cool. thanks matt.
Old Apr 24, 2009 | 03:07 PM
goober35's Avatar
Originally Posted by VeTTeMaNC486
too bad I couldn't get these springs when I installed my tsunami 3 weeks ago
I might be using them on my tsunami in a couple of months
Old Apr 24, 2009 | 03:16 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Let us know when we can help!
I'm digging your screen name BTW. I often refer to people as goobers, LMAO!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 25, 2009 | 11:07 AM
405HP_Z06's Avatar
What is the exact coil bind on these springs? The original post states "below 1.080", how much below?
Old Apr 25, 2009 | 11:13 AM
TVWilkes's Avatar
1.08 is advertised coil bind.
Old Apr 25, 2009 | 11:17 AM
RevGTO's Avatar
Pontiacerator
What is the recommend duration/lift range for usage of these springs? Would they be overkill for something like 22x / below .600?
Old Apr 25, 2009 | 11:27 AM
405HP_Z06's Avatar
Originally Posted by Matt@Texas-Speed
We've got this kit rated at a max lift of .675"
So, using a 1.800" install height with a max lift of .675" would put the safety margin at ONLY .045". That's under the .060" best practice.
If 1.080" is the CB height than .660" lift is max @ 1.800" installed height.
Old Apr 25, 2009 | 11:58 AM
TVWilkes's Avatar
There is a built in margin at .675 lift. True coil bind is lower than 1.08. We have run this spring with a .708 lift cam installed at 1.800. Until more testing is complete the recommended lift is .675.
Old Apr 25, 2009 | 12:01 PM
goober35's Avatar
I will be in contact with yall. I will be getting h/c and all parts needed.
Old Apr 25, 2009 | 12:16 PM
405HP_Z06's Avatar
Thanks for the response, but it doesn't make sense. Max lift is a simple mathematical calculation.
(Coil Bind + .060) - Install height = Max Lift
Why not publish the actual measurement?
Old Apr 25, 2009 | 12:45 PM
01ssreda4's Avatar
^^^quiz em about the timing chain failure issue too while youre at it.......geez. OP nice product, glad to see the time was put into improvements in an already good product making it better and affordable. cheers to you.
Old Apr 25, 2009 | 01:24 PM
  #32
TVWilkes's Avatar
We measured the coil bind at 1.04. The engineered specs is 1.08.
Old Apr 25, 2009 | 02:05 PM
  #33
405HP_Z06's Avatar
Old Apr 25, 2009 | 02:06 PM
  #34
405HP_Z06's Avatar
Thank you.
Old Apr 25, 2009 | 07:35 PM
  #35
383lt1impala's Avatar
Are these over kill for a ms4 cam with stock rockers?
Old Apr 25, 2009 | 08:11 PM
  #36
JFM-jr's Avatar
Thats his way of saying your being a pain in the *****, when in reality you raise a legitimate question IMO.
Old Apr 25, 2009 | 10:03 PM
  #37
flintwrench69's Avatar
I just got my cam kit from you guys, & got PRCs. Are they the same springs you are discussing, only difference from the pics I see is mine have a chrome look? The ones in your pics do not.
Old Apr 26, 2009 | 08:14 AM
  #38
JimMueller's Avatar
Originally Posted by Jason 98 TA
In a effort to offer the most complete line of products for our customers, we will continue to offer the standard PRC Platinum Spring Kit for budget minded customers. We're also currently working on a beehive single spring that should be ready to go in the next couple of months!
Tell me more about this beehive spring... how will it compare to the PRC Platinum's I currently have and to the other high-quality beehive springs available? I'd like to switch to a single beehive so long as it won't affect reliability nor decrease performance.
Old May 4, 2009 | 09:26 AM
  #39
GrannySShifting's Avatar
Ran .708 but minus the valve lash dont forget that.
There is no "recommended margin" of .060" You really have to know whats going on with your exact valvetrain. We have run .030" from bind static. Dont recommend doing that, but has been done.
Old May 19, 2009 | 10:42 PM
  #40
Kurtomac's Avatar
so who's installed their new springs...how are they running...I'll be putting mine in this weekend assuming i can bum a compressor from someone
