gain from milling 243's
Old Apr 24, 2009 | 11:58 AM
dre2013's Avatar
Default gain from milling 243's
so i am considering having my ported 243's milled a little to bump compression. my cam is a comp 224/230 .592/.609 112+4LSA. how much material can i safely have milled from my heads without worrying about flycutting? and how much hp gain would i receive from the milling? thanks guys
Old Apr 24, 2009 | 12:04 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Milling will definately give a good kick in power across the board. The valve size you decide to run depends a lot on what you can do as far as milling. With the camshaft your running you should be good for a healthy bump in compression & therfore hp. We offer cnc porting LS6 heads with valve job, and milling for $650. Give us a call if we can help you with what we do with our packages!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Apr 24, 2009 | 12:39 PM
dre2013's Avatar
hey thanks for the quick reply! i have a machine shop about 1/2 mile from my house so i will probably have him do the work..i would like to keep the stock valves(to keep costs down...this is just my setup for this season, i am planning a 6.0 turbo setup for next year)
