Help with removing crank pulley
Old Jan 3, 2003 | 02:14 PM
bomax's Avatar
Default Help with removing crank pulley
I loosened the crank bolt, took it out some, then I put the 3 arm tool on and went to work. I got to about the last 1/2 of the tool when all of a sudden, with each turn I did, the car jolted forward a bit! I don't know what to do. I tried prying the pulley off but it won't budge. ???
Old Jan 3, 2003 | 02:22 PM
SLowETz's Avatar
Default Re: Help with removing crank pulley
Not sure which pulley you're using but on the ASP, I ground off the shoulder of the bolt on the bench grinder so the pulley(hole)would clear it. Others have used longer threaded rod. Either way works........
Old Jan 3, 2003 | 02:25 PM
Colonel's Avatar
Moving to the EXTERNAL Engine section... <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
