Ok bent valve i think options
Old May 1, 2009 | 10:47 PM
mvrotc's Avatar
Default Ok bent valve i think options
So i pulled my valve covers off today and saw the first spring was compressed and the valve not all the way up . I think that means i have a bent valve. The car will still run but i dont want to run it because i wanna try and save the bottom end. Is it possible to do new heads, valves, a whole new valvetrain including lifters and rockers, instead of replacing the motor? the bottom end already has a cam in it so i figure id just keep building this motor.
Old May 2, 2009 | 12:59 AM
Paint_It_Black's Avatar
Yes, you can change the entire top end no problem with the engine in the car.
