destroked motor?
The guy had a 302 LS1, said it was fun to "drive around", not friendly on street, but revved nicely, Xpensive, and made in the area of 550rwhp if I remember correctly. Thats nice, but when you have to turn 7800+ to get it, no thanks, if I am not at bonneville then the time I hit 8000+ every cop in the district will know where I am.
If this makes you happy then build it. Look at all the people that said the ASA is too much for a street LS1, and before you know it they are in A4 LS1's, almost in mine, but anyway you could find some new ways to improve it and be superhero status, or lay back with a 9k rom spinning cop caller and trying not to hear all the "I told you so's"....your call.
Charlie
I've been playing with this idea of destroking an ls1 and have had the ideas that it could be a dead ringer to make 500 rwhp
....however the price you will pay is torque. With that short of a stroke you make a shitload of hp but not as much torque....so you make up for it with Gears
At this point in the process finding the valve train to support 8k rpm is hard and very expensive. Rods you can come by...pistons too, even the crank if you have a couple of grand to blow, but the springs and lifters for the ls1 are hard to find that would support it, not to mention the lift on the cam. After all whats a hot rod without a nice lopey cam
hp/liter is not a serious way to compare motors. It unfairly favors small motors.
Take for instance, the new S2000. It makes 120 hp/liter, compared to an LS1's ~55 hp/liter.
Now consider:
The s2000 is ~600 lbs lighter, almost a second slower in the 1/4, and is epa rated to get worse gas mileage.
But it makes twice as much hp/liter!
Benefits of that over a nicely setup 346 with a turbo setup?
Of course, if they could they'd go bigger, but probably only in bore as much as practical!
Anyways...
There is no logical reason related to power to destroke an LS1. Increasing the stroke isn't always the best way to increase power, especially with FI, but a shorter stroke isn't going to give you any more useable power anywhere in the RPM range. You'd have to spin well past 8000 RPM to start worrying about piston speed with a stock stroke.
it's the area under te curve man. if you've got identical CI motors, and one makes 450 ftlbs @2800 then it drops to 290's at 5800, and the other makes 450 ft lbs @ 2800 to 5800 which motor will make a faster car? duhh.. the latter.
i'd change the setup to a 388, and use C5R heads, solid roller, ect ect.. but thats just me
a motor with a rod/stroke combo like this would make SICK flat torque, all the way to 8k rpms w/ the right parts. now, with the gear and tire choices, everyone knows that more gear and taller tires = more MPH. w/ 28's and 5.57's something like this would mph freak nasty.
i just like the idea for a light car, w/ a glide and some stuipd gears. like another datsun LS1 project.
that'd be a ball. The Best V8 Stories One Small Block at Time
Anyways...
For a given displacement the faster they spin it the greater HP.
joel
The Trans Am series is 311 CID max Displacement. they use anywhere from a 2.9-3.1 stroke, and the accomodating bore. Big bore, short stroke, 8200 series limited redline.
The same cars can step up to the Grand Am series, but the CID rule is now 377. Funny, no one runs a 311 CID engine any more
BTW, who says you can't have a 400ci+ engine that turns over 8000 RPM? Mine does. And it'll turn at least 8500 before I'm done with it. IMO, a 4.125 bore with a 3.7-3.8" bore would be perfect for turning 9000 RPM. This would make for a 396-406ci engine. You'de still have the CI to make some serious power and you would have a descent enough rod to stroke ratio to get there before the point of deminishing returns, IMO (I'd study further into this to dial the final idea in.)
"u can have a high displacement engine making 1000 ft pounds and it redlines at 4k rpm, but if u have a motor making 600ft pounds and it revs to say...8500 rpm, the torque monster has no advantage in power at all. more usable RPMs are always good."
You're not going to make anywhere near 1000 ft lbs of TQ NA with an LS1 based engine but in a little fantasy world, let's just say you did...
1000 ft/lbs EVEN IF it were made at the 4000 RPM redline (and of course peak TQ is made well before the redline) would be only 761 HP. 600 ft/lbs at 8500 RPM would be 971 HP! Well of course 971 HP is going to beat 761 HP. But...gimme 1000 ft/lbs at just 5500 RPM instead and let's see what happens. That would be 1047 HP at that TQ and RPM (reminding once again that I'm just talking about HP at the TQ peak, NOT peak HP which would be well after the TQ peak...just for an example.) I'll take that engine over the 8500 RPM 971 HP engine any day of the week.
