oil pressure??
Displacement = 5.7 L. / 346 CID
Bore x Stroke = 99mm x 92mm / 3.90" x 3.62"
Compression Ratio = 10.1:1
Horsepower = 345/350 HP @ 5,200 RPM
Torque = 350/375 #-Ft. @ 4,400 RPM
Redline = 6,000 RPM
Fuel Cut OFF = 6,200 RPM
Firing Order = 1-8-7-2-6-5-4-3
Spark Plug Type = 41-931
Spark Plug Gap = 1.524mm / 0.06"
Oil Type = Mobil 1 (E) 5W-30 Synthetic or Equivalent
Oil Capacity = 6.5 Quarts / 5.7 L. (With oil filter change)
Oil Pressure (Minimum - Hot):
1,000 RPM = 41 kPa / 6 psig
2,000 RPM = 124 kPa / 18 psig
4,000 RPM = 165 KPa / 24 psig
Length = 519mm / 20.43"
Width = 460mm / 18.11"
Cylinder Bank Offset = 24.10 mm / 0.949"
Bank Angle = 45 degrees
Deck Height = 234.7 mm /
its so hard to believe that the motor would still hold together with only 24psi of oil pressure at 4k let alone 6psi at idle!!
and here is the video i took...
http://s78.photobucket.com/albums/j1...=VIDEO_001.flv
it made me
but my old motor an every other ls1 or ls based motor vehicle iv ever ridin in or drivin have had 35-40psi at 1,000 45psi+ while driving an around 60psi+ under WOT?
