TDC or compressor for valve springs?
John
I used the air method. Not to bad except for cylinder #8
I think if you still have your Timing cover off, their is a diagram that shows when what cylinder is at TDC, this seems like it would be easier, but I have never done it that way.
Check outBlains Page
under modifications/ cam install, their are a couple of pics of the tools i used.
I hight recommend them
for tdc i just took out all the plugs, put my finger in cyl 1 spark plug hole and turned the engine over until air stopped coming out. tdc right there, changed 1 and 6. than did the same thing in cyl number 3, than 5, than 7
worked great
John
