Cam Recommendations for 429
Old Nov 1, 2003 | 05:36 PM
GTBMad's Avatar
Default Cam Recommendations for 429
Motor is a few weeks from completion still havent decided on camshaft have some thoughts on this but would like some input.Below is a basic idea of what it is.
Comp 11.2-1, can support lift of .650 @400lbs, CompR lifters, yella terra 1.7 ratio, REV limit 7000rpm. Valve size 2.055 inlet/ 1.60 ex. Auto tranny upgraded, 42lb injectors (waiting for LSX manifold) Bottom end Lunati billet rods,Callies XS Magnum Crank, Diamond Pistons, Darton Wet sleeves.
Old Nov 2, 2003 | 06:51 AM
11 Bravo's Avatar
There aren't many cams out for strokers. 240/240 or 242/242 seem to be the most used in the street motors. I personally would like to see someone try a big reverse split, like a 248/242 115 or something. Never heard of it for a 42* before, could be badass. Do you know what your heads flow?
Old Nov 2, 2003 | 12:29 PM
GTBMad's Avatar
Heads did flow over 300 they are being redone to suit the larger bore and we are waiting on new numbers.Have been looking at a special cam in 25+ area.
