No oil pressure!! Oil flow schematic?
It's not a bad oil pressure sensor, the sensor is bone dry.
So where does the oil go to after the filter? Anyone have a detailed schematic? I'm hoping there is an oil plug somewhere that got left out, cause i don't feel like pullin this motor out.
So far i have verified that the front oil plug (drivers side next to pump) is there and so is the oil diverter (barbell looking plug) is there too.
Any ideas?
So I apologize to everyone if my answer is not close and I'm way off target, but here goes nothing.
I had the same problem with oil not getting to the top of the motor, until I looked closely at the oil diagram for a 5.3 gen 3 vortec, the two ports above the oil filter, are there for a engine oil cooler, and on a 5.3 L Gen 3 motor, the two ports can not be blocked off, one of the two ports sends oil to the top of the motor, so it needs a bypass adapter, not a blocking plate, if the plate is installed. Oil cannot be sent to the top of the engine.
