Z06s have a smaller cam base? ....
When you get an after market cam, you will likely need slightly longer pushrods to compensate for the smaller base circle. But, if you mill the heads or deck the block, that changes the distance between the cam and the rocker arm. Therefore, you need to measure the distance with a pushrod checker ($20 from Jegs/Summit).
