HELP ASAP!!
Old Feb 16, 2003 | 04:00 AM
blackssrider00's Avatar
Default HELP ASAP!!
Hey guy's,
I need some major help here..Okay here is the problem i have a 00camaro ss I have a dry nitrous kit by (NOS)that i have only used 2ice with a 75 shot on there,auto lites 103's Whisper ram air K&N air filter, hypertech 160thermo ,box, air sensor housing JBA headers no cats with a borla 3inch exhust my .later today when i was going to work my car would barley take off in first gear as the same for second 3 and 4th and when i was gaining speed the car would jump back and fourth like it wanted to launch and then it would slow down also my shifter would shake and vibrate really bad.I thought it could be a loose spark plug . now this has happend to me before where my spark plug wire was loose from the actual spark plug so i just snapped it back in and the car ran fine I checked them again everything was okay(it was always the same spark plug that popped out also) .....granted my SES light is on because i have not cats on my car already ,but the light was blinking and i havent seen this before so any help would be great guys!!! i dont want to take everything out and bring it back to the dealer when it could be something small
thanks for your help
JOE
Old Feb 16, 2003 | 04:53 AM
RUF SS's Avatar
Default Re: HELP ASAP!!
When you have the SES light blinking, you have a major problem. For example, one cylinder is not working right. 75 or 100 shot is fine for a stock engine. But, if you had the NOS on and miss shifted hitting the rev limiter, it could cause a problem. You could bend a pushrod or break a spring easy!
I would say, check all the wires very carefully. Then, change your spark plugs if the wires are ok. I think that is where your problem is!
One more thing! Get NGK TR6 plugs gaped at 45, they are way better!
Old Feb 16, 2003 | 10:19 AM
wrencher's Avatar
wrencher
Auto-lites in a LS1 <img border="0" alt="[shoot]" title="" src="graemlins/gr_guns.gif" /> Blinking ses light is a missfire occuring now. I would 2nd the ngk recommendation.
