Red T.A
Old May 13, 2009 | 05:56 PM
William 5900's Avatar
Default Red T.A
I have a 1999 Trans am I am getting ready to put a 418 stroker in it and I would like to know what it would take with this block to hit 550 or more to the ground. The heads I have is Patriot Performance Stage 2 heads but I am going to send them back to upgrage to stage 3 The cam I have in the block right now is a comp cams solid roller with the lift at 694 intake 691 exhaust.
P.P told me me heads will not lkast with the solid roller so I plan on pulling the cam out and putting in something else. I would like to hit these numbers just on motor. I also plan on a 300 shot of gas but I want to get to the 550 to 600 range just on the motor. Any help on what I would need in the block? I have the 418 in a crate just waiting to be put in.
Thanks
Old May 15, 2009 | 08:40 AM
I would like some help. Does any one have any ideals in here? I was hoping I got alittle help from someone. I am just trying to see what way I can go. The cheaper the better.
Thanks
Old May 15, 2009 | 11:47 AM
PREDATOR-Z's Avatar
Different heads with the right cam, but definitely better flowing heads.
Old May 15, 2009 | 12:15 PM
Thinks for the reply. The stage three head from p.p won,t work? If price was a problem what heads would you go with?
Thanks
Old May 15, 2009 | 12:20 PM
PREDATOR-Z's Avatar
It is not that they won't work but to achieve 550 rwhp it wont be easy.
If on budget I would look at a set of well massaged L92s
Old May 15, 2009 | 12:41 PM
WSsick's Avatar
listen to pred, hes one of the most well respected around here. let him spec you a cam, **** let him build you a great combo that you can go out and buy! id say youre going to need some real nice flowing heads, some decent compression, and a good size bump stick. also, if you are changing the drivetrain any, (9"/12 bolt0 that will skew dyno #s, so dont be concerned if you do not hit them.
Old May 15, 2009 | 12:48 PM
I already have a solid roller in it and it,s 694 on the intake with a 691 on the exhaust. It is a 418 stroker block. I am not sure my p.p heads would even work on it.
