To those w/ compression ratio calc abilities
Old Nov 3, 2003 | 10:29 PM
Jammer's Avatar
Default To those w/ compression ratio calc abilities
Trying to end up about 8.5-8.6, heres the set up..was I on or off...
6.0 block, bored 30 over (late edit john, sorry)
6.125 rods
-18 cc dish pistons
70cc chamber
.057 gasket
stock crank
Old Nov 4, 2003 | 12:16 AM
John B's Avatar
Moderator
8.43 assuming 4" bore, 4.1" head gasket bore, 0.057" head gasket thickness.
Old Nov 4, 2003 | 11:36 AM
Old SStroker's Avatar
6.125 rods
-18 cc dish pistons
70cc chamber
.057 gasket
stock crank
I get 8.71 with the piston .010 out of the hole,
8.55 at zero deck and
8.40 with piston .010 down in the hole, which might be too much quench height.
Sounds like you are right where you want to be.
Old Nov 4, 2003 | 05:06 PM
Jammer's Avatar
Thanks SStroker! Hey since ya got the Calc out, what if I wnt w/ 76cc chambers(AFR)...that puts me about 8.1???
