Advice on Roller Rockers - Strange Setup
The cam I have is a LPE GT2+3 207/220 .573/.580 117.5. My heads are milled a little, .030. Pistons are stock.
Can I use these 1.75's without issue or am I asking for trouble? Any help would be welcome!
For example lets say at TDC you have .100" cam lift, which equates to .170" at the valve, with the 1.75 rocker you are now at .175", so you can see that P to V at TDC is only decreased by about .005"-.010".
With that low of duration you should be good to go. Its only when you get up to 228-230 duration on intake side with your heads milled .030" that you start having problems.
If it were me I would not run that much lift, FWIW, we just had a cam only Z06 on our dyno make 417 RWHP with less then .580 lift.
Chris
