should i run it? (pitted piston)
btw they are sand size pits, not massive ones.
why not put the piston at TDC and take a GOOD picture of it? its hard to see $hit in that pic
just throw a stocker in it but try to find the cause.
I blew a hole threw #1 last summer and just swapped it out and have had no problems
im not sure if that piston will work with what i have. mine are getting cut .100, but its not a stock head, so im not sure if the angles are right.
If it where me i replace them and not risk it.. I would never use a part that is question... if there's any thing that look's wrong chance's are it is wrong and will break if you push it to far.
