parts list help for swap
ls6 heads milled 20 thousands with patriot gold springs
arp head bolts
ud pulley and belt
ls6 ported oil pump
gm LS2 HD timing set
tpis headers
yank stall
swapping 3:15 rear for 3:42
fast 36 lb injectors
so i know i will need head gaskets timing gaskets and water pump gaskets so i am looking for the part numbers i will need. I guess i should while i have the trans and rear out replace all the seals back there so those part numbers as well.header gasket part numbers, gm bolt part number for the ud pulley, also i am guessing i need a trans cooler so what would be the cooler to get? I know i am asking alot but i just want to make sure i have everything needed for the transformation! Also I am looking for someone to help me with the install as i am a bit of a rookie and will gladly help turn wrenches and pay you for your help and I can come to you if you are in the va md pa or nc area
ud pulley and belt - powerbond KPBU1117SS25 comes with belts, bolt and pulley
$263.80
ls6 ported oil pump - SD3964b 149.75
gm LS2 HD timing set - gm chain is 12586482 - 37.80
tpis headers
yank stall
fast 36 lb injectors - FAS303608 - 349.95
you will have to let me know if you need the rear end gaskets and such. i answered all that i could.
$263.80
tpis headers
yank stall
correct me if i am wrong.
front cover gasket, front cover seal, new crank bolt, head gaskets, valve cover gaskets (maybe), water pump gaskets, the headers should come with gaskets, if not you can use the gm ones...then the rear cv shaft seals and maybe rear axle housing gaskets.....anything else?
hahahaha john i dunno thats why i was posting here and listed what i had so i could get input on what i still need to buy and hopefully the part numbers of what i need to buy
so on with the list.....
we have convenient part kits that will encompass most of what you wanna do.
SD28902 - cam and head swap kit.
$279.95. I can take the head bolts out for you though, since you have them...take $45 off then. then its just some of the rear end gaskets....ill let you know on those tomorrow
