msd wire life
Old May 20, 2009 | 07:46 AM
edzsilverss's Avatar
Default msd wire life
I'm tunning my car up and I was wondering how many miles can you run msd wires before they go bad? Is there a easy way to check them out before buying new ones? I'm going to change the plugs for sure but don't want to spend 70 bux on wires if I don't need to. Any help would be appreciated.
Old May 20, 2009 | 11:31 AM
99blancoSS's Avatar
Unless they are degraded (ripped, torn, burnt) they should be fine. You can check them with an ohm meter.
If you do need them I offer the best deal on the planet on MSD
Old May 20, 2009 | 11:35 AM
LS1BLKSS's Avatar
Banned Village Idiot
how many miles are on them?
Old May 20, 2009 | 12:04 PM
NemeSS's Avatar
i have around 30k miles on a set
Old May 20, 2009 | 12:24 PM
they have about 50,000 on them. I'll check them tonight. What would a good one read btw?
Old May 20, 2009 | 12:32 PM
99blancoSS's Avatar
no loss ! Take the leads and touch them together and see what the reading is. Then touch one to each end of the wire and see what the reading is. If the initial is reading lower than the second reading then your getting loss/resistance across the wire. If they are the same the wire is fine.
