are these right?
Old May 21, 2009 | 06:15 PM
Gregorya24's Avatar
Default are these right?
are these the right pistons for for stock bore and stock rods? i have 59cc heads with a 232/237 613/613 112lsa and im having ptv issues my heads and cam shaft was made for -4cc valve relief pistons but i decided to save money on rods and machine work so will these work in a stock bore and stock rods
http://texas-speed.com/shop/item.asp...d=119&catid=38
Old May 21, 2009 | 06:51 PM
PREDATOR-Z's Avatar
yes...read the description. But you are not even honing the bores? (double check on that)
Old May 21, 2009 | 07:09 PM
Gregorya24's Avatar
i got the machine shop to hone the cylinder so would they be these then?
http://texas-speed.com/shop/item.asp...d=118&catid=38
