What Guages Are Necessary?
Imo I wouldn't use aftermarket gauges unless you plan to run a power adder (nitrous or forced induction).
http://www.neweraperformanceparts.co...=intcept-all|0
In my opinion...you don't really NEEEED anything other than the stock gauges. If you're turbo, a boost/vac gauge is worth it...if you're making big power, fuel pressure is worth it...if you've got nitrous and you want to make sure the bottle will last the complete run, bottle pressure might be worth it...if you're like me and you want to put the car on air ride...a pair of dual needle air pressure gauges is worth it...oil temp can be nice because you can sorta tell when you've been a little too hard on the car (like at an auto-x) and need to let it settle down for a bit...but it's not an emergency, because even if the oil is a tad too hot...if your foot isn't in the throttle, and the engine is just idling with decent (maybe a little low due to the heat, but still some) oil pressure...it will probably survive.
If you tune the car yourself, wideband gauge is worth it...if you don't tune it yourself, it's a waste of money.
I also run an electric Fuel Pressure, but that's only because I modified to a return fuel system with an adjustable regulator. A wideband will let you know if you're not getting enough fuel otherwise (it will go lean). Stock oil pressure gauge works good for me. Oil temp isn't high on my list of vitals either. (Can monitor that via the H2O temp).Anyhow, that my $0.02. BTW, my mods are very similiar to yours.
Iam with this guy. I got my Aeroforce interceptor 2 years ago love it
