Cam help
Old May 27, 2009 | 03:03 PM
simplman's Avatar
Default Cam help
My dad has a 2000 SS Camaro A4 3.73 gear. The car has SLP long tubes, high flow cats and SLP Loud Mouth cat back. He is looking to do heads and cam nothing to radical it’s a DD he is looking to increase power and fuel millage and suggestions on a setup. Thanks.
Old May 29, 2009 | 08:10 AM
simplman's Avatar
anything?
Old May 29, 2009 | 08:29 AM
SLOW30th-TA's Avatar
A popular "all around" cam is the 224/224. Texas Speed has one, Thunder Racing, and most other companies. I had the Thunder Racing 224 with their Stage 1 heads, pretty nice set up and good all around power. Livernois has this set up that is pretty much everything you need. http://www.livernoismotorsports.com/...t.phtml?p=1761
Good Luck.....or if you want just cam only go with Thunder Racings Reverse split cam 230/224.
Old May 29, 2009 | 08:31 AM
99blancoSS's Avatar
373 gears an auto and you want to increase gas mileage by caming it??
Old Jun 1, 2009 | 11:55 AM
simplman's Avatar
Those are the stock gears it was special ordered that way and it gets 19-20 around town as is, he was told it would work I am just doing some reserch for him.
Old Jun 1, 2009 | 12:31 PM
texasthrottle's Avatar
gas mileage will definitely be falling. any cam in the 224-228 range will
work fine.
