lifter question
Old May 28, 2009 | 07:18 PM
venom99's Avatar
Default lifter question
my motor is going to be shifted at 7000 to 7400 should i use ls7 or morel lifters can some people chime in and let me know what they are shifting at with what lifter
Old May 28, 2009 | 09:05 PM
vsocks1's Avatar
I am planning on a 7000 rpm rev limiter setting. I went with Morel lifters to be safe and some 3/8" Manton pushrods, Jesel Rockers.
Old Jun 1, 2009 | 02:54 PM
venom99's Avatar
any one else running anythign besides morels
Old Jun 1, 2009 | 03:38 PM
Unertl42's Avatar
did you consider the "caddy" lifters?
Old Jun 1, 2009 | 06:21 PM
Nissan LS240's Avatar
I was told ls7 lifters would work at 7000rpm so thats what I have, but my motor isn't running yet so I can't tell for sure it works, but that is what I am running.
Old Jun 1, 2009 | 07:59 PM
venom99's Avatar
i plan on shifting at 7400 and the cam in under 650 lift any one want to chime in on this the more ino will help would caddy lifters work the cam is right under 650
Old Jun 2, 2009 | 07:40 PM
bigboykilroy's Avatar
I have the caddy lifters in mine, so far so good 6800 rpm
Morel = Best
Caddy = Better
LS7 = Good
Old Jun 3, 2009 | 07:41 AM
venom99's Avatar
thanks for the info guys i guess i have no other choice but get the morels
Old Jun 3, 2009 | 09:28 AM
99blancoSS's Avatar
I've got them in stock.. But heres the thing... how consistantly is it going to see 6000-7000 rpms ??
Morel has a a few stages of lifters and if you are going to constantly be in the 6000-7000 range say as in a road racing application then you might want to step up to the Morel "pro" series. It gets its roots from offshore racing where the rpms are contantly held at or near maxium. The lifter is made slightly different to enable it to withstand the pressures that are exertated in those etreme situations.
Old Jun 3, 2009 | 03:31 PM
00SS6spd's Avatar
Sorry to thread jack... I'm building a motor revving to a similar range (6,800-7,200), with Comp 850-16 lifters. So out of curiousity how would you guys rank the Comp 850-16's in comparison to the Morel, Caddy, and LS7 lifters? I'd guess Morel, Comp, Caddy, LS7?
Old Jun 3, 2009 | 03:37 PM
bad2dbone's Avatar
i had stock lifters obviously were not working now i have ls7 havent got my car back so ya but was told car sounds good and no more problems
Old Jun 4, 2009 | 07:43 PM
venom99's Avatar
the car is going to be street driven alot and see alot of track time so i would say it will be in that range alot
Old Jun 4, 2009 | 08:45 PM
99blancoSS's Avatar
But for how long at a time? If your just touching 7k during 1/4 miles runs, its different than a constant 6500 rpms for 45 minutes while your lapping on a road course.
If your just hitting that upper rpm for short bursts then the regular Morel should be fine but if you going to hold that kind of rpm constant then I would seriously consider stepping it up. BUT your talking a huge price difference so you need to be sure of your application.
Old Jun 4, 2009 | 09:08 PM
venom99's Avatar
oh ok gotcha it is just going that high when i shift normally driving is going to be like 3 to 5k
Old Jun 4, 2009 | 10:46 PM
383lt1impala's Avatar
Why are the caddy ones better? And if I had the cash I would go with the morels. I never heard one bad thing about them.
