The right bottom to match the top.
Old May 28, 2009 | 07:27 PM
franksaltz28's Avatar
Default The right bottom to match the top.
Right now i have ls6 heads and a ms4 cam for my 98 z28. I have a little extra monney so i figured what the hell ill build the whole motor while im at it. Im tring to figure out what would be a good match for the top end i have. I was thinking either an iron block 408. or stock block 383 stroker.
Ive heard that the 408 is to big for some ported ls6 heads but i dont know.
P.S. I want to spray the motor, 150+ shot.
Old May 29, 2009 | 08:36 AM
99blancoSS's Avatar
IMO bigger is always better. Yes those heads will work with that cam and the 408. I have a customer who took our 408 short block and put stage 1 LS6 heads on top, ms4 cam made 470/440 with an LS6 intake.
It's not that its to big, its that some heads dont flow enough to allow it to reach it's maximum
Old May 29, 2009 | 06:20 PM
what kind
of iron block would i use for a 408?(lq9,lq4,or just a 6.0cast iron block.)
Old May 29, 2009 | 07:15 PM
SOMbitch's Avatar
Originally Posted by franksaltz28
what kind
lq4 or lq9 is the 6.0 iron block so either is fine.
Old May 29, 2009 | 09:33 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
I definately prefer the 408 over the 383. We typically stock 40 short-blocks & will be running a special on them next week! If we can help you with your combo please give us a call. I'd be glad to help anyway I can!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
